TPS Y pipe fitment?
TPS Y pipe fitment?
How does this kit fit. My brother is thinking ofgetting coated pacsetters and the TPS catted y. But i could have swore there was fitment issues. What do you guys think?
Mine fits ok.I tried putting it in piece be piece and was having trouble
then I assembled the whole thing in the driveway and put it on as one piece
and this worked much better. You may have some y pipe banging at first
and you can adjust for this and or jam heater hose in the parts that
are banging.
are banging.
mine was a PITA to put together and ground clearance sucks, im thinkin about cuttin out the cats and uttin straight pipes in cause theres no way to lower it with those cats
My TSP catted y-pipe was put on with band clamps. It banged, moved all over the place and souded like my car was going to fall apart. I was depressed, and took my car to a muffler shop the very next day. They replaced the band clamps for welds(not collectors). They held the y-pipe away from the body and welded it. They also added a strip of steel as support from the y-pipe, into the stock rubber bushing spot. Then I had them tack weld the passengers side heat shield away from the y-pipe. The y-pipe doesn't bang anymore, and suprisingly tucks up real nice. I have the eibach pro-kit and still have good clearance considering. Long story short....with some work, you can make the TSP y-pipe fit very nicely and not bang. I'm very happy with the outcome after the muffler shop fix. The best part is, it only cost me $20, which is less than I spent in band clamps.
Originally Posted by Transgression
don't even get me started about fittment on the TSP Y-pipe
TSP y-pipe
TSP y-pipe
