Whining sound from under my hood !!
Okay here's the prob.
When my car gets up to running temperature I start to hear a whining sound from under the hood as I accelerate between shifts. Could that be my power steering pump or something else ??
Any ideas guys ???
Any ideas guys ???
Originally Posted by bastien
if you removed the !AIR, I think it's the line you are supposed to plug with a screw, leaking. Mine sounds like a supercharger, its awesome
Originally Posted by brad8266
Maybe the Easter bunny slipped a Procharger under there on Sunday morning.
Originally Posted by TransAm_00
Everyone knows the Easter bunny is not real.
Originally Posted by BIG BAD BLACKSS
Have you checked your power steering resevoir? Mine was just barely touching the bottom of the lil plastic dipstick and making a lil noise, also had a heavy feeling steering wheel at times. Topped it off and it feels like a brand new car again.
i had what seemed to be that exact problem, my car was still under a used warranty , i had no idea what it was, but they fixed it and told me it was the belt tensioner and i had to replace belt after that worked perfect
Any ideas guys ???
Any ideas guys ???
I'd start pulling belts. Do you have a short belt to bypass the power steering?
Pull main belt to be sure it's a belt driven noise. Then AC belt to eliminate AC system. Then if you have a short belt put that on.......and all it leaves is the water pump.....or alternator but you should see something on the guages if the alternator is going.
Rev the car up while under the hood. Thats what I did, and it was clear that my Power Steering Pump is done. Even though it still works, and it's full, it whines past 1,800 RPMS when warmed up. I even tried pumping out the old fluid and filling it back up with new, but no luck.
i just put on a 305 dollar gm water pump today thinking it was the damn water pump and i spent 5-6 hours sanding and polishing my valve covers and when i got it all back together like a little kid on christmas day i fired it up and what to you know.... SCREEEEEEEEEEEEEECH!!!!! its power steering pump, theyre known to go out at 90k
