2.5" or 3" pipe for exhaust set-up
Old 04-19-2006, 12:29 PM
383camaroSS's Avatar
Default 2.5" or 3" pipe for exhaust set-up
wich pipe is better all the way through for a exhaust set up? car isnt lowered..
Old 04-19-2006, 12:31 PM
brad8266's Avatar
if its a y pipe I would go 3". If true duals I would go 2.5" if you plan on lowering.
Old 04-19-2006, 03:05 PM
no im dont plan on lowering...true duals though 3" or 2.5"
Old 04-19-2006, 03:06 PM
s346k's Avatar
i have true duals through 3" with x and magnaflow 4x9 mufflers. it sounds totally amazing, VERY deep with normal driving/idle...and f'n screams @ wot.
Old 04-19-2006, 03:08 PM
where did you get your x pipe from?
Old 04-19-2006, 03:18 PM
s346k's Avatar
i bought the universal x pipe kit from jegs - $90. only used the x with actual install..
Old 04-19-2006, 03:22 PM
hey do you think that set up fill fit on my car i have a th400 and a spohn t/a that connects to the brace where the old one was where the y-pipe ends? do you think ill have enough clearance?
Old 04-19-2006, 03:30 PM
Default clearance
will i get enough clearance with spohn t/a with driveshaft loop?
Old 04-19-2006, 04:34 PM
cmp007's Avatar
When your cruising or just driving around normal is your exhaust really loud? Im planning on a setup alot like yours and want to know when im on the interstate and stuff if it will be roaring the whole time or not.
