Possible to run rest of piping for TSP Duals?
Old 05-15-2006, 05:50 PM
YouCantCmyZ28's Avatar
Default Possible to run rest of piping for TSP Duals?
I want the TSP Duals but is it possible to later on run the rest over the axel out the back?
brad8266's Avatar
yes..
Old 05-15-2006, 06:00 PM
you2slo's Avatar
a couple have run it under the rear end with little clearance issues.
Old 05-15-2006, 07:52 PM
anyone ever run the rest over the axel?
Old 05-15-2006, 07:54 PM
brad8266's Avatar
yeah, plenty of people have it over the axle. Over is kinda expensive to get done.
Old 05-15-2006, 08:05 PM
i just wanted to make sure its possible with the TSP duals because its dumped kinda close to the axel. just didn't know if it had enough room to go up and over
Old 05-15-2006, 09:50 PM
That's what she said...
TheBlurLS1's Avatar
It would be pretty tough to get the TSP kit over the axle, as you would have to have one on each side of the center section. Most people with TD's over the axle, make BOTH pipes cross the tq arm where the x-pipe is, then run BOTH sides over the passenger side. They then run across the back with one to have a pipe on each side.
I have my TSP duals run under the axle with absolutly NO problems, I would recommend it to anybody. You can see pics in my sig.
Old 05-16-2006, 02:51 AM
how much was it extra to run it under?
Old 05-16-2006, 03:25 AM
TheBlurLS1's Avatar
It was $130 for them to install the cats, extend the exhaust, and mount the tips. I supplied the tips and cats.
All the prices are laid out in that thread.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I went over the axle and on either side of the center section. It can cost upwards of 300$ in some cases.
Old 05-16-2006, 06:29 PM
thats not bad at all, orangepeel you ran it over with the TSP duals? any pics
Old 05-16-2006, 06:38 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It is not the TSP duals, but the concept would be 98% similar.
Old 05-16-2006, 07:17 PM
98% harder, there not made to go over because of the way the piping is run....at least thats what i hear from the blur and the tech at TSP
Old 05-16-2006, 07:20 PM
TheBlurLS1's Avatar
I'm not saying it could not be done, by any stretch, but it would take a bit of work.
Best thing to do is go by a shop, get it on a lift, and see what you need to do. You will proably HAVE to scrap the PHR support.
