cleaning MAF
Old 05-17-2006, 07:27 PM
wmcrn's Avatar
Default cleaning MAF
what can you use to clean the MAF without damaging it?
Old 05-17-2006, 07:33 PM
FL01SS's Avatar
https://ls1tech.com/usa/showthread.php?t=468979
Old 05-17-2006, 09:06 PM
wmcrn's Avatar
appriciate it.
Old 05-17-2006, 10:29 PM
Camaro Rick's Avatar
Something I've heard - Can't you just take a quetip soaked with rubbing alcohol and wipe it clean?
Old 05-17-2006, 11:04 PM
Element's Avatar
I've used a q-tip sprayed with a little carb cleaner, and never had any problems.
Old 05-18-2006, 06:41 AM
mattsls1's Avatar
electric cleaner
Old 05-18-2006, 11:35 AM
LS1Formulation's Avatar
Have to use electronics cleaner because it evaporates completely, whereas carb cleaner or brake clean leave a slight amount of oil on the MAF.
Old 05-18-2006, 12:58 PM
rgaynor85's Avatar
CRC electrical parts cleaner or now they also sell MAF/sensor cleaner
Old 05-18-2006, 04:34 PM
gillbot's Avatar
+1, carb cleaner can leave a residue.
Old 05-18-2006, 05:02 PM
Abe99's Avatar
Can you get CRC MAF cleaner from an auto part store?
Old 05-18-2006, 06:56 PM
Moderator
davered00ss's Avatar
Nappa actually sells a MAF cleaner spray.
Old 05-18-2006, 07:30 PM
Viper's Avatar
Radio shack carries the contact cleaner.
Old 05-19-2006, 01:06 PM
sdbrown84's Avatar
Just use a high percentage rubbing alchol and a cue tip. Be gentile and you wont have a problem. Use air intake cleaner to blow the dust from the screen AFTER you seperate the MAF.
