Finally it arrived... my bassani true X duals!
Originally Posted by TransAm_00
Did you notice anything diff with the TR plugs? I just ordered some from Thunder Racing, should arrive shortly. I got some Spiro wires also. Tough to put in???
Yeah, it took me 12 hours to take the stockers out. #6 and #8 plug will kick your ***! It's not the issue of putting the new ones in, its taking the old ones out.
Make sure you've got gloves and the right rachet/extensions/sockets and possibly a good 2-3 hours if you're good taking those things out.
Originally Posted by bene
Hopefully I'll get it installed tomorrow. I'll take pictures.
But it does run all the way back tho correct?
Just curious, it was a kit I was considering, but i was under the impression it wasn't for LT's
Originally Posted by DirtyJohn
That bassini kit is built for stock manifolds no?
Where is it not fitting? Is it too low where the __________ is? Does it bang against the _______? Does the ________ not slide into the ________?
More info please.
I was thinking about purchasing this down the road. Is there drone at 60 mph? How deep is the tone at idle and durring 2k rpms and WOT? How does it compare to what you have had on your car or what you have heard?
Thanks,
Chris
More info please.
Thanks,
Chris
wondering what the issues are as well. seeing as i have it on both cars with no fitment issues. one on stock manifolds and cats (as built for) and the other with headers. pics are up on both websites. click links in sig.
More info please.
Thanks,
Chris
More info please.
Thanks,
Chris
i need to see pics of where they hooked the front pipes to x-pipe. that's where the whole problem started. if they would've solved that issue first, then the rest would have went together fine. most likely, if they would've trimmed off some of the end of the 90* bend pipe that goes into the x-pipe, it would've shifted it over and not hit.
in this pic here, you can see the pipe i'm refering to. now that i think about it, i had to trim some off of it to get the x-pipe in the correct position. it's possible, bassani cut it a little long (i'd guess 1"). without being there, i can't really say where it all went wrong. but, i'm willing to bet $1.00 that's where it all started as the whole system is shifted to one side.
the issue i have is why didn't they see the x-pipe hitting and take care of it first before hacking on your $1000 system. they should have put the system together, then as they were tightening the supplied clamps, adjust the system until it fit and cleared. after that, then if you wanted it welded on, then weld and remove clamps.
I noticed smoother idle on TR55s and crispier acceleration .
Originally Posted by mrr23
i took the passenger side coil pack and AIR tube off to access the plugs. one hour total time. all from the top.
