help with radiator
help with radiator
i am taking out and replacing my radiator with a used one, anyone have any writeups or help with taking one out? im having trouble with the fans right now. thanks in advance
sean
sean
leave the fans on and pull everything all at once.
1) drain coolant
2) remove lid and rad cover
3) remove the hoses
4) unclip the connectors from the fans
5) unclip the harness from the shrouds
6) lift up a little and seperate the radiator from the condenssor (2 locating tabs - 1 on either side)
7) lift up and out
1) drain coolant
3) remove the hoses
7) lift up and out
Originally Posted by Clark Kent
never mind, i got it. that was a ************ to get out, i cannot imagine getting out the engine.
^ you don't have to evacuate the ac to remove the radiator and fans as 1 piece. I remove these parts all the time with varrying jobs on these cars. Every time I've pulled the radiator it comes out with the fans attatched.
