Need help with vacume line
I started the car up for the first time today after a winter long "mod fest" and noticed a small vacume line with a 90* rubber boot fitting hissing. It was the line that use to go to the small diaphram/check valve (don`t really know what it was) located near the fire wall, above valve cover on the drivers side above the #7 cylinder. I`ve removed all emissions/A.I.R. related equipment and if memory serves me a air line from the pump ran back to that valve but I`m not a 100% sure as it was a while ago when I removed that stuff. I noticed when I put my thump over it it affected idle. What is this line and what do I do with it? Thanks in advance for any help. Oh, and for the record it`s a 2002 Z28 A4.
Re: Need help with vacume line
This is interesting. I have a 98 TA. I removed the AIR system completly after installing the FLP headers. I did [not] have a small vacuum line that needed to be capped. I wonder if this is something used on the later model cars?
Ron,
Ron,
The only hoses I had that were associated with the AIR system were the large hoses with the check valves that connected to the headers and a "T" in that line that connected another large hose that traveled along the inside upper edge of the engine compartment down to the AIR pump.
Ron,
Ron,
I'm almost positive that this setup was implemented in the 2001+ models. What leads me to this conclusion was an engine breakout graphic I saw on LS1Info.com as part of Terry's pushrod check tutorial.
The instructions said something like "...on the 2001+ models, there's thingy."
"Thingy" (LOL) I came so close to calling it that! You know it`s funny, as much time as I spend researching these LS1`s and how they operate you would think I would know what the hell that thing was! So SScott, you just capped it and that seemed to be fine? I could`t quite trace where the small line went to last night but if it`s sucking air it would have to be comming off the intake some where right? Thanks very much for the replys fellas. This site flat out rocks!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
LOL - Couldn't think of the name myself, it was early, and word "thingy" seemed to fit... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Just cap it and you'll be fine. I've been running w/o problems for about 5,000 miles now since I pulled the AIR system.
