Egr On 2002 Z28 Stripper Model
Old 06-23-2006, 12:36 AM
zrater's Avatar
Default Egr On 2002 Z28 Stripper Model
EVERY ONE SAYS NO EGR , BUT THIS CAR HAS ONE ITS LOCATED IN RIGHT
BACK CORNER OF MOTOR LOOKS LIKE A FLYING SAUCER WITH VACUM
HOSE HOOKED TO TOP OF IT SMALL HOSE. THEN THERES ANOTHER
BIG HOSE HOOKS TO IT AND GOES TO THE EXHAUST. I WANT THIS
**** OFF. WHAT TO DO CAN I JUST SHUT OFF AND CODES TO OR
NOT THAT EASY THANKS , KINDA BORED . TO LIT UP TO MOVE...
Old 06-23-2006, 12:40 AM
2002ssls1's Avatar
2002 Camaros did not have teh EGR setup. I think what you are talking about are the AIR lines that run from the air pump to the exhaust manifold. If this is correct, you can take the AIR pump and all of its accessories out, and put block off plates on the exhaust manifold. This will cause the SES light to come on if you do not have the code deleted.
Old 06-23-2006, 12:42 AM
Joel_SS's Avatar
Yep that is not the egr it is the air pump. no EGR on 01 and 02 F-bods
Old 06-23-2006, 12:44 AM
That's what she said...
TheBlurLS1's Avatar
Check out the AIR FAQ or do some searching. BTW...........
Old 06-23-2006, 09:41 AM
TRANSAM75's Avatar
NO EGR! NO EGR! NO EGR! no egr! nooooo egr!!!
Old 06-23-2006, 09:49 AM
zrater's Avatar
thanks guys i should of no that that was the air pump. if i shut it off
will that help withperformance or any other advantage to this shut down
of the air pump.. thnaks every one............................................
Old 06-23-2006, 09:55 AM
ICRAZY6's Avatar
The pump itself it electric. You'll loose about 5-6lbs of the front of the car and clean out alot of garbage that you don't need. Performance...... Not that I can see. I did it when I got my headers, looks good with it not beeing there. SES light yeah, but you can deleat that. There's No drop in vacuum pressure anywhere after you remove it. I would say do it and don't look back.
Old 06-23-2006, 09:58 AM
Tech Resident
ChocoTaco369's Avatar
lol that's not the AIR or EGR. the image forming in my head tells me that's your brake booster pump. if i'm right, you run seafoam through that hose when you wanna clean your top end. I HIGHLY RECOMMEND YOU DO NOT TAKE THAT OFF!!!
Old 06-23-2006, 12:03 PM
2002ssls1's Avatar
I just read his description again, and I think you are right. I feel like a tool.
Old 06-23-2006, 12:20 PM
Tech Resident
lol don't worry about it. the reason why AIR popped into everyone's mind is because you're talking about EGR so everyone's brain is in emissions mode. it must be the AIR pump! it's funny looking and has hoses...
i knew it was the brake booster because i've seafoamed my car. if you've never seafoamed, you've probably never had a reason to even lay eyes on your brake booster. honest mistake.
Old 06-23-2006, 12:47 PM
2002ssls1's Avatar
You da man
