Truck Oil filter ???
.... i used to use a van style for my 84 camaro oil seemed to stay cleaner longer. why not use it if its the same thread/ daimeter etc. who cares if it says its for ls1 or not if its only difference is how long it is.
That's what she said...
I run the K&N 2006 which is the truck filter, no problems from it and I noticed a boost in pressure over the crappy Frams I used to run. The oilfilter is the first thing the oil hits after the pump, so a larger one will offer more flow and help boost the pressure for the rest of the stuff on down the line.
Originally Posted by orangeapeel
The biggest/longest one you can find will generally work better in your favor. You just have to make sure you don't leave it on a speed bump.
If you are hitting the longer oil filter on a speed bump then you will hit the oil pan on it as well. You're screwed if that happens regardless
