Picked up a P/P TB, opinions? *pictures*
Old 07-11-2006, 08:56 AM
azab21's Avatar
Default Picked up a P/P TB, opinions? *pictures*
Just thought I'd see what you guys think! Thanks!
Old 07-11-2006, 09:58 AM
Grimes's Avatar
kinda hard to see from the pics, but looks nice
Old 07-11-2006, 10:14 AM
farnoush's Avatar
That throttle bodies nice, but that shirt your wearing is even nicer
Old 07-11-2006, 10:48 AM
That's what she said...
TheBlurLS1's Avatar
Originally Posted by farnoush
That throttle bottles nice, but that shirt your wearing is even nicer
Looks like Boyd Coddington!
Nice TB though! Someone spent some time on that one.
Old 07-11-2006, 11:29 AM
shouldaboughttheZ's Avatar
did you knife edge it? It is hard to tell in the second pic.
Looks good though.
When I did mine, I didn't use the filler for the sensor area.
Old 07-11-2006, 12:23 PM
Trunion King
bene's Avatar
Looks pretty good.
Old 07-11-2006, 12:24 PM
azab21's Avatar
No knifing, and I don't know that I will knife the edge before installing it, as I do not want to threaten the idle..
Old 07-11-2006, 12:34 PM
Trunion King
bene's Avatar
You'll only just trimming the 12 o clock/6 o clock of the throttle body blade thickness.
Old 07-11-2006, 01:16 PM
azab21's Avatar
what would be the best method of accomplishing this.. i don't want to go overkill
Old 07-11-2006, 02:52 PM
Bo White's Avatar
Blade has been drilled for a cam, you runnin a larger cam?
Old 07-11-2006, 03:48 PM
TheBlurLS1's Avatar
Yes you can replace the blade. What year is your car and what year did this TB come from? You might need to swap out the shafts/cam on the TB's as well. If you're not sure what year car it came from, swap the shafts anyway.
Make sure to use some blue loctite on the screws when re-installing the blade.
Old 07-11-2006, 03:52 PM
azab21's Avatar
No, I'm not... Is this going to severly affect my idle? Can I Replace this blade with the one from my stock TB?
Old 07-11-2006, 03:53 PM
azab21's Avatar
It came from a 2001, so the shaft and cam should be fine. how hard will swaping the blade's be?
Old 07-11-2006, 04:44 PM
Trunion King
bene's Avatar
Do you see those 2 torq screws on the blade? Unscrew them. Blade should slide right out behind the TB when you open it up.
Old 07-11-2006, 04:48 PM
Trunion King
bene's Avatar
Yeah, I noticed about that hole was a little bigger than my TB hole.
Also you see in this picture how my blade is sharpened both on opposite ends.
Old 07-11-2006, 04:50 PM
Trunion King
bene's Avatar
Another look at the blade's edge.
Old 07-11-2006, 05:12 PM
dnm12's Avatar
dyno tune for me, no larger of a hole necessary
Old 07-11-2006, 06:16 PM
azab21's Avatar
bene, what tools did you use to knife the blade like that? would there be other downsides to leaving the current blade other than higher idle lower mpg? and would there be any benefits?
Old 07-11-2006, 06:28 PM
azab21's Avatar
also guys, does anyone know what the stock inner diameter of that hole is? i'll measure the ported tb with a caliper and see what it comes up.. how severly would this affect idle? in terms of rpm
Old 07-11-2006, 07:15 PM
Bo White's Avatar
.145" on the #70125 blade(mostly on truck TBs) and .165" on the #79651 blade.
