View Poll Results: Putting it together
muffler clamp u-bolt
5
8.77%
2 bolt ball flange
2
3.51%
3 bolt flange
1
1.75%
band clamp
42
73.68%
weld it
7
12.28%
Voters: 57. You may not vote on this poll
Pacesetter connection
Old 09-05-2006, 08:19 PM
fastlt1's Avatar
LS1Tech 10 Year
Default Pacesetter connection
What is everyone using to connect their pacesetter long tubes to the rest of the exhaust?
Old 09-05-2006, 10:44 PM
Shallow Bay's Avatar
A couple of band clamps that were included in the TSP true dual system.
Old 09-05-2006, 10:45 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I went and bought some s/s 4" band clamps...
Old 09-06-2006, 12:09 AM
fastlt1's Avatar
LS1Tech 10 Year
Was it the butt joint type or the lap joint?
Old 09-06-2006, 01:05 AM
zach_ws6's Avatar
u clamp on one side, band clamp on the other. and yes, ghetto is my middle name.
Old 09-06-2006, 09:05 AM
jmm98LS1's Avatar
lap joint stainless band clamps.....zero leaks.
Old 09-06-2006, 10:49 AM
lastcall190's Avatar
First off, IMO the collector connection sucks *****. The collector is too short, the clamp is interfered with by the 02 sensor bung, so my TSP duals leak from both collectors using the band clamps. Now I have to trim some of the system, move the TSP pipe a little bit down stream to allow a tight fit. Other than that, yes all SS band clamps.
-J
Old 09-06-2006, 10:23 PM
Cstick's Avatar
I hate seing U bolt clamps on exhaust. Get band clamps. The ones that came with my TSP kit are like butt joint clamps, they comform well to the step in the pipes. I accidently ordered a lap joint band clamp from Summit one time but returned it and just went and got a butt joint locally. I do have some U bolt clamps but they are turned so you can barely see them, and about impossible to get a wrench on the bolts. If you do use U style, paint them cause they will rust quick.
Old 09-06-2006, 10:42 PM
blkbird's Avatar
Band clamps from jegs...
Old 09-07-2006, 08:32 AM
Traitor's Avatar
I have a shitty u-clamp on it now, plan to replace it with a band clamp.
Old 09-07-2006, 08:40 AM
erikthegoalie's Avatar
weld man...what else?
Old 09-07-2006, 10:37 AM
Dustin's Avatar
I welded mine because the x-pipe i made was kind of off but I grinded the welds off to remove it for a tranny swap and it went back on with ease...two band clamps hold it now. If it holds well with band clamps then use them...if its hard to keep on then weld.
Old 09-08-2006, 10:39 PM
Beasst8's Avatar
I would never weld for the reason of needing to take it off for future maintnence. I used band clamps from TSP as well.
Old 09-09-2006, 09:39 AM
ModGod's Avatar
I just read your sig and almost wet myself.....
Old 09-21-2006, 12:00 AM
Revelation Z28's Avatar
you can band clamp the Y pipe to the cat too?
how much are the clamps?
Old 09-21-2006, 12:31 PM
NHRAMAN's Avatar
Exclamation
lap joint ----1/2 the clamp is 1 size, the other 1/2 is another..
Old 09-21-2006, 02:45 PM
2KThunder's Avatar
Ive had no luck with a leak free connection. The drivers collector has the o2 bung close, and the pipe gets squareish. The stepped bandclamp wont fit, the 3 inch straight one wont sit flush on the top due to the collector becoming oddround, Im taking it to a shop tomorrow and see what he can do.
Old 09-21-2006, 09:18 PM
fastlt1's Avatar
LS1Tech 10 Year
So does the end of the header come expanded to slip over a 3 inch pipe.
Old 09-23-2006, 08:20 AM
2KThunder's Avatar
The header collector is 3". The Y-Pipe is expanded to fit over the header.
Old 04-19-2008, 03:06 AM
Apollo0526's Avatar
Dual 3" cut outs right off the headers welded to a Y
