Can you take apart the throttle body?
Old 10-31-2006, 05:13 PM
Mrs. Ronin's Avatar
Default Can you take apart the throttle body?
I am having some parts of the car powder coated and am trying to figure out if I can take the TB apart so the housing can get done. You can't do it with the rubber seals in there.
DOes anyone have a link to how to dissasemble it?
Thanks
Old 10-31-2006, 05:46 PM
jay_99z's Avatar
Take off the screws in the TB blade.
Remove blade.
Take off TPS sensor.
Tap the shaft with a hammer until it falls out.
To put it back together I used a 7/16(I think) socket and tapped the ring back on the shaft.
Old 10-31-2006, 06:39 PM
Restricted User
Smokin87TA's Avatar
Make sure you dont loose the very small washer under the tps sensor. Also th IAC comes out faily easy. Just make sure to pay attention how it comes apart.
Old 10-31-2006, 10:11 PM
Bo White's Avatar
Once you make sure you dont loose the washer just throw it away, thats what I do with it
However, the rubber oring thats on the IAC....need that badboy for the reassembly
Old 11-01-2006, 09:27 AM
Mrs. Ronin's Avatar
AWESOME I got it apart, thanks for all the help. I will be doing the porting on it when I get it back from the powder coater.
I appreciate all the help everyone has given me. I will post pictures of what the car looks like when I am all done!
Old 11-01-2006, 10:29 AM
jay_99z's Avatar
Yeah....I was wondering if that washer even did anything. I put one together without it and didn't notice any difference. I guess the shaft can't really go anywhere with the blade in there....
Old 11-01-2006, 03:33 PM
5_02ls1's Avatar
id do my porting before the powdercoat all it takes is one chip to ruin the powder coating jost my opinion
Old 11-02-2006, 07:46 AM
Mrs. Ronin's Avatar
Yeah I thought about that BUT I needed to have everything to the coaters by a certain time and I didn't have time to port it before. I am going to try to fill in the big holes at the top like it shows in the article I saw. Where can you get aluminum pipe? and metal filler I suppose you can get at Auto Zone or something.
Quick Reply: Can you take apart the throttle body?
