Who removed steering linkage on header install?
Old 12-08-2006, 06:40 PM
noxiouSS's Avatar
Default Who removed steering linkage on header install?
On pacesetters? is it hard to do it and how do i do it?
Old 12-08-2006, 06:42 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I don't think that you have to.
Old 12-08-2006, 07:15 PM
white_camaro's Avatar
i had to remove the linkage. its very easy, just two bolts. one that you should be able to get from the top and one more that you will have to get from the bottom. after the bolts are removed the linkage kind of slides out.
Old 12-08-2006, 07:19 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
ELDELBROCK....Nope.
Old 12-08-2006, 07:34 PM
The PAT WS6's Avatar
i did u pretty much haev to w. hooker headers.
Old 12-08-2006, 07:35 PM
Hennytime's Avatar
what about for macs?
Old 12-08-2006, 07:36 PM
Raise's Avatar
not with pacestters u wont have to. done probably a dozen pacesetter swaps with no problemn yet
Old 12-08-2006, 08:23 PM
Hell'sChariot's Avatar
I didnt take it out, just took the bottom bolt out and swung it out of the way.
Its cake! Dont sweat it.
Old 12-08-2006, 08:37 PM
lgobraves's Avatar
i didnt have to touch it at all
Old 12-08-2006, 09:08 PM
hazard2k's Avatar
negative on pacesetters also.. Leave it in. If you do need to take it out for some reason, its real easy like mentioned.. Just 1 bolt and it will swing away enough to put pretty much anything in
-Jeff
Old 12-08-2006, 09:26 PM
DONAIMIAN's Avatar
When I pulled my jethots off they damn near hit me in the head.
Old 12-08-2006, 09:28 PM
gillbot's Avatar
It depends on the car.
I'd say out of all the header installs I've done, it has been about 70% needed it removed, 30% didn't.
Old 12-08-2006, 09:29 PM
2kta--89formula's Avatar
I opted to cut the tab off the block instead.
Old 12-08-2006, 10:53 PM
MY02REDWS6TA's Avatar
I just installed my Pacesetters a couple months ago and I had to just slip the linkage off....no big deal. Also had to grind the tab on the block a little. I was surprised I had to do either of those after reading so many posts about NOT having to do these with Pacesetters. I agree each car is slightly different. Probably could have 'persuaded' them past the linkage but I didnt want to scratch the coating off....but the tab needed to ground a little either way. I did them on a lift which made things a ton easier.
Old 12-09-2006, 02:03 AM
That's what she said...
TheBlurLS1's Avatar
My pacesetters fell out/in. Removing the steering linkage is no problem. Remove the top and bottom bolts, then knock the bottom end off the rack, then slide the top off. I like to use some blue loctite on the bolts after I clean them up on re-assembly.
Old 12-09-2006, 02:25 AM
parbreak's Avatar
Didn't have to with Jet Hots
Old 12-09-2006, 07:53 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I need pictures and video...
Old 12-09-2006, 09:46 AM
slow trap's Avatar
i put a set of pacesetters on and they almost installed themselves.even left the plugs in also.the qtp's were,well,what didn't i have to take off ?
Old 12-09-2006, 10:11 AM
BigDB's Avatar
with my flowtechs I was doing mounts at the time so I unbolted the mount and jacked the motor up for extra room.
