QTP stainless cutout?
Old 12-22-2006, 08:04 PM
98camaroLS1M6's Avatar
Default QTP stainless cutout?
i got one and noticed that there is a lip of metal where the two pieces are welded inside. should I grind/smooth this down? i know this would increase flow with the cutout open but it will probably be less efficient closed b/c gases will get trapped there. Is that lip there for a reason? should I leave it be?
Old 12-22-2006, 09:05 PM
Any opinions?
Old 12-22-2006, 10:52 PM
WILWAXU's Avatar
Doubt it will make a big difference. But if it's bugging you, get rid of it.
Old 12-23-2006, 02:18 AM
That's what she said...
TheBlurLS1's Avatar
That lips there because its a sloppy job. My flowtech cutout that I butchered was horrible.
You can fix it, but it's not going to gain you anything. When the cutout is open, you have to remember that you've now got two 3" paths for the exhaust. It's not like it's all trying to flow out of the cutout.
Think of it more as a pressure relief than an exhaust diverter....
Old 01-24-2007, 09:23 AM
Yeah, it has two 3'' paths but one has less pressure and it is closer for the exhaust to escape. The 3'' cutout has such a lip that it looks more like a 2'' cutout, I agree with little gains, but nothing, I doubt that. With a lip like that more will be forced out the rest of the exhaust rather than bypassed out the cutout. (ie w/lip 40% gases cutout, 60%through catback) vs. (50%cutout, 50% through catback). Thanks for the replies guys!
Old 01-24-2007, 10:00 AM
JerseyLS1TA's Avatar
I have the QTP cutout, I didn't notice any lip on mine. But it is a quality piece and gives a nice throaty obnoxious sound.
Old 01-24-2007, 11:57 AM
lucky you!
Old 01-24-2007, 12:27 PM
ilirw325's Avatar
yea my QTP looked like crap too.... shitty welds also....you could see light through in a couple places that I had to touch up.
what do you expect out of china
Old 01-24-2007, 01:52 PM
Quick Time's Avatar
98camaroLS1M6
You need a lip for the othe pipe to weld to. You do not want the weld to crack Also the cut in the staright pipe is on a angle which make it large than a 3" diameter hole.
ilirw325
Mind your business. And for your info we make them in house, so quick talking smack.
Old 01-24-2007, 01:58 PM
Beasst8's Avatar
I have had no problems with mine and been very happy with it.
98NATA's Avatar
Mine had a little bit of a lip but the welds looked good, sounds pretty good tho so the lip doesn't bother me at all
Old 01-24-2007, 05:40 PM
[QUOTE=Quick Time]98camaroLS1M6
I definitely understand why there is a lip now, I love QTP products(just got your headers), I just wanted to know if taking that lip down by using a dremel would gain a little more power(minimal). My belief is yes. Thanks QTP for awesome products.
Old 01-24-2007, 05:45 PM
TheBlurLS1's Avatar
Your dremel is going to have a helluva time with grinding that down! I'd use an air die grinder and a rotary file.
Old 01-24-2007, 06:29 PM
die grinder FTW then.
