my intake is filled with oil ,how to fix?
Old 12-22-2006, 08:28 PM
TNTaddict's Avatar
Default my intake is filled with oil ,how to fix?
my catch can is not doing the job i have oil filling my intake , how can this be fixed?
Old 12-22-2006, 08:31 PM
INMY01TA's Avatar
Get a different catch can. My intake was FILLED with oil too. Bone dry with my catch can.
Old 12-22-2006, 10:28 PM
Caribe's Avatar
Which catch can are you using?
Old 12-23-2006, 01:33 PM
BerryWS6's Avatar
catch can didn't work for me so I got rid of the PCV system and have filters on each vavle cover
Old 12-23-2006, 02:39 PM
That's what she said...
TheBlurLS1's Avatar
I just run one breather on the driver side filter and it works great. Do some searches on breather setups and you'll find a nice solution.
You can buy a cheap oil cap, drill a hole in it, then stick an autozone special in it.
Old 12-23-2006, 05:56 PM
INMY01TA's Avatar
Bought it from someone on LS1.com. Looks like this:
Old 12-23-2006, 11:27 PM
GR33N GoblinM6's Avatar
if it doesnt have a filter element in the catch can.. there is no point to having one.. real catch cans have this so the oil vapor is trapped and is not sucked back into the intake..
Old 12-23-2006, 11:42 PM
black01_WS6's Avatar
How do you know the catch can isn't working. Oil in the intake takes some tome to go away. You can try spraying seafoam's deep creep in the intake or take it off and clean it.
also like said above make sure the catch can has a filtering element inside.
Old 12-24-2006, 07:18 AM
INMY01TA's Avatar
Well mine keeps it dry which is better than some of these "real catch cans" above have been doing.
Old 12-24-2006, 07:45 AM
1fast01's Avatar
Very intersted in this pos...
Old 01-02-2007, 07:03 PM
Snake Eater's Avatar
I had 1 on my silvy with LPE GT1, heads, 5.3. It got about half full in 2k miles so just out of curiosity I put a second one after the first one. I checked them about 500 miles later and they both had the same amount in them. They both had filters and held about 1/5 qt. I gave up on it.
Old 01-03-2007, 05:02 AM
MNR-0's Avatar
Do it right and vacuum pan it
Old 01-03-2007, 06:54 AM
N4cer's Avatar
Go with an air/oil separator. Mine works so well I've considered selling kits on eBay. You guys think it would sell? Full kit ready to hook up for like $55 shipped? That's cheaper than one decent catch can, and works better.
Old 01-03-2007, 02:54 PM
sabersaw30's Avatar
Put some pics up I want to see it.
