Oil Catch Can **PICS**
Very easy to install. I put it on in about 15 mins, then parked the car..
Any way here are the pics
BEFORE
AFTER
i hope that my PCV is ok. i took it out to inspect it, i got it back in, and got that metal peice back around it. Just want to make sure it is ok. And i got the hose back around it to make sure that it seats properly...
NOW WHAT DO YOU ALL THINK???
BEFORE
AFTER
Originally Posted by 5_02ls1
Why 2 seperators?I may be wrong but aren't those water seperators for a paint gun?Looks ok though creative.
B/c i have heard that the 1st does not always catch it all.
And the cans are from an air compressor actually. do a search. about 95% of people are runing those exact same ones
The problem with those is that they are way to small and will only hold so much oil before it gets sucked in again. My AMW can will only go for about 200 miles before the oil gets past. If you let those go for a couple weeks(maybe even just a couple days), You will notice the level of oil in them won't change. And that line is definately pinched.
Ok, so how do i get it unpinched?
Import Patrol
WOW, you did that all by yourself. I thought you just tightened the hose clamps.
Originally Posted by HotWhipT/A
Seriously??? You can see where it is right? Its by that one zip tie. You unpinch it by using common sense! Give it more slack Jonas.
i will remomve the zip tie. i am goign to put it around the neck, like crawlinws6 suggested. Hey go into the appearance section you will see the new gauged i put on
I'm not trying to be a dick, but I would be embarassed and made fun of by my friends if I opened my hood and they seen that. It looks like you robbed your air compressor of parts. I will give you an A for creativity though!
Creativity??? do a search 90% of people here used the exact same thing as i did!!!!
Import Patrol
LOL!!!
