ideal problem
idle problem
Ok guys having a little problem, Just installed my new trans, stall, and manifold. when I started the car the Idle is at 3200 rpms.what didi I do wrong
Back again, now I noticed the oil pressure is pegged out I did replace the oil pressure sending unit but what would be causing the oil pressure problem
well I thought I fixed the the vaccum line but when I started the car back up the idle is back up to 1500, I am so pissed off. I have tried every thing. and the oil pressure problem I found the wire came off.
Did you use the LS6 coolant lines with your new intake? I'm assuming you swapped from LS1?
If you didn't modify the intake or replace the coolant lines....it's possible that the intake isn't seated the whole way.
No I used the new ls6 coolent lines. It idles at 1100 in park for about 10 sec then is starts going from 1100 to 1400 I dont now if it is the fact that it is a 85 mm manifold and the there is also a new 3500 stall and it needs a tune or if I am still missing somthing what does it sound like to you?
Idle Air Control motor - of the two electrical plugs attached to the right side of the throttlebody it is the one on top. Should be held in by two bolts. The whole piece slides out.
That's what she said...
newbie here ( tell by the post) what is a IAC motor?
Post 13 is correct. The plug on the driver side of the throttle body, on the top, is the IAC. IAC is a plunger that opens/closes to maintain the engines needed airflow by bypassing the throttle body blade. It helps control idle.
The plug below the IAC is the TPS (throttle position sensor).
thanks now that you say that I did clean the throttle body while it was off, It was full of black crud and I wonder if some thing got in there and clogged it up. I dont think it is a vaccume line because I checked every thing a 1000 times and some times it will idle fine and then when you start it up again it will start going from 1000 to 1300-1400 and I cant here any vaccume leaks over the straight headers thanks for all the input.
Also, did you break the knock sensor wire clips off before installing the manifold? The knock sensors are in the valley cover, small wires that run under the manifold. This clip usually clips the wires to the vent tube, which you should have removed with the LS6 coolant lines. It's tall enough to cause an interference with the manifold sealing for some people.
Well its dark right now so I cant take the throttle body off and check the IAC tonight but I will do that tomarrow and I did take the clips off the knock sensor I will go check the vent fan now. thanks
well I just got home and the vent fan works fine and it idles fine in park then when I put it in gear it starts surging from 900 to 1200 is this normal
