How to tell if you have the ls6 or ls1 engine block
I found this on another site and figured I'd post it here for everyone's education...
(note: this has nothing to do with the ls6 INTAKE which all 01 & 02 cars have, this is specifically about the engine block).
"Apparently there have always been two version of the LS1: One built in Montupet, and one built in Nemak, Mexico. They use two different methods in creating the block, and apparently the Nemak block is a stronger, more performance oriented block. (The material properties were about 10% higher/stronger. Nemak uses a low-pressure precision fan process, more high performance oriented.). When the Z06 Corvette came out, GM decided to use the Nemak plant to build the LS6 block, since they built stronger blocks. So Nemak built LS6's, while Montupet built LS1's. Since there were so many LS6 blocks made, several made it into F-bodies. Numbers from GM are that about 10-15% of 2001 cars had LS6 blocks, and 25% of 2002 cars did. To confirm if your 2001-2002 F-body has an LS6 block, grab a mirror and a flashlight. Open the hood and head over to the driver's side to try and see the back of the left-hand deck, above the transmission flange. A cast-in #12561168 denotes the LS6 block. And if you aren't able to see the number, you may be able to tell by the block's luster-the Montupet plant cast a shinier block, the Nemak plant made the duller block. The Z06 block (LS6 block) is not only much stronger, it also has 87% better ventilation between bays, which equates to less pumping losses at high RPM's."
Read somewhere about this a few years ago - If I remember correctly the LS1 has a "bulls eye" on the flat part on the passenger side block front, right behind the water pump/tstat housing - the LS6 is smooth. Remember going out to my car to check. If my camera was working I'd post a pic...
that claim was made at the intro of the LS6 because of the material removed from the base of the cylinders that allows the bottom end to breathe better, there is no conclusive evidence that the LS6 block is any weaker because of this
The following users liked this post:
Joe Dollor (10-19-2021)
