View Poll Results: what intake would suit my needs best?
LS6
21
77.78%
Edelbrock Victor Jr
4
14.81%
pro products
2
7.41%
Voters: 27. You may not vote on this poll
which intake would suit my needs best?
Old 02-15-2007, 07:54 PM
Z28_DAD's Avatar
Default which intake would suit my needs best?
im going with a T-REX cam. other bolt ons are in sig.
so what would be best?
LS6
Edelbrock Victor Jr w/an elbow
pro products 85mm
Old 02-15-2007, 08:10 PM
Tainted's Avatar
id go with a FAST 90/90
Old 02-15-2007, 08:14 PM
Z28_DAD's Avatar
dont feel like dishing out that kind of cash. if i did want to spend that much i wouldnt have posted this. please dont post to tell me to go with a fast or anything else. i put those 3, because those are the 3 im debating on. if i was THINKING about a fast, it would be up there.
so no im not going with a fast....too much $$$$
Old 02-15-2007, 08:18 PM
Tainted's Avatar
ok no need to get hostile lol. well i dont know much about the other 2 intakes but the LS6 isnt gonna be yur prime intake for high rpms with a cam
Old 02-15-2007, 08:28 PM
Restricted User
WS6nJAX's Avatar
with stock heads the ls6 and a ported t/b should be just fine. if there is a set of performance heads in your future i would save up for a 90/90 set-up. didnt say fast...
Old 02-15-2007, 09:05 PM
Z28_DAD's Avatar
im going to stay with stock heads till i build a 400+ci motor
Old 02-15-2007, 09:43 PM
DuronClocker's Avatar
Well Jay, I remember you said that you were going to turn the car more into a track car, I'm going to say the Vic Jr. It will give you a better high-RPM powerband, which will suit that cam (though maybe not the heads til they flow a bit more) the best, and you'll spend most of your time up high anyways.
Old 02-15-2007, 10:29 PM
dpw41285's Avatar
pro products(pp). i have seen their work and tis a beauty. you thinking 85/85 pp? I will be using a weiand with the 85pp tb and have the mani ported to the heads and tb. when you do build your motor you can still use the pp mani and have it matched to your head. just my thinkin dad
Old 02-15-2007, 10:38 PM
Z28_DAD's Avatar
track car, daily driver, eh whatever, its all the same
i think im going to try and make the most stripped down, pain in the *** to drive DD
Old 02-15-2007, 10:43 PM
So get the Vic Jr
Old 02-16-2007, 10:40 AM
lsx24's Avatar
Those aren't even in the same category. A vic jr is carbed! But I would get a ls6 no doubt.
Old 02-16-2007, 12:26 PM
Z28_DAD's Avatar
not of it has injectors and a throttle body
Old 02-16-2007, 01:40 PM
lsx24's Avatar
I didn't know you could run in that configuration.
Old 02-16-2007, 03:33 PM
Galen's Avatar
I am in your same situation...just already have the LS6. I am waiting for the PP 96/96 combo to be available. When I talked to them last week, they said it should be ready in the next couple of months.
Galen
Old 02-17-2007, 08:21 AM
moe00z's Avatar
go with the ls6
Old 02-17-2007, 10:26 AM
mycamaroSS's Avatar
go with the ls6
Old 02-17-2007, 11:09 AM
Order 66's Avatar
Go with the LS6. You need lots of volume to take advantage of the fast.
Old 02-17-2007, 04:48 PM
mike#9's Avatar
None of them are the optimal choice. But if you are hell bent on not getting a Fast, then I would probably recommend a LS6
Old 02-17-2007, 06:13 PM
Red99TA's Avatar
Wrong. That cam is plenty big to take advantage of a 90/90 setup. Out of those 3 I would say LS6. You can pick one up for around $300 used.
Old 04-17-2007, 11:55 AM
radkon's Avatar
LS6 will get you the best gain for the buck.
I only got an extra 10 HP (lost 7 tq) on my FAST 78. For $700 it doesn't seem worth it.
