what kind of gains can i expect?
the car is a 1999 automatic z28....usually what kind of gains can i expect from adding some pacesetter long tubes, and ory? does a different brand really make a differene if they all serve the same purpose? i know the quality on some are better but what kinda numbers can i expect? only mod on the car is slp loudmouth catback, no cats
the only effects from exhaust systems are:
1. diameter, for stock LS1 with bolt-ons, i wouldn't go larger than 3 inch system.
2. bends in pipes, smoother the better.
3. cats. having a complete after market exhaust with LTs, hi flow cats give you the proper backpressure needed for a stock bolt-on LS1. if you've upgraded your cam and/or heads and don't have to worry about inspection, then go with an ORY.
for an A4 LS1 tuned, you'll gain about 35 rwhp.
You'll gain about 30 rwhp with headers and ORY. Most all headers will dyno close to each other, the difference in price is mainly the material they are made out of: stainless steel or not stainless steel.
