My camaro cone crazy *HELP*
I'm in the middle of no where right now.
Any way i stoped at the traffic light where my gages light went low and the car start going like it has a cam with the service engine soon Logo came + check gages sing. When i turned of the car i waited for 15 minute and try to start the engine again it wouldnt start. The funny part was when i tried to start the car the trunk opened by it self. What could be the problem
Sounds electrical. Take it somewhere and get the codes scanned to see what they are. Try resetting the computer, see the FAQ on how to. Give some more info, any recent mods added?
Dude i'm in the middle of the desert and i'm using my mobile phone right now lol
Originally Posted by Ls1LikeNoOther
battery/alternator connections?
Originally Posted by ELMiN8oR
my alternator is new but about the battery i just came out of the garage and he disconnected the battery and reconnected it back. Will this be the problem ?
Originally Posted by 2001NBMZ28
Is the car turning over at all? Check the battery connections - when mine died the rear hatch mysteriously popped too.
Originally Posted by ls1amit
Ground issue my friends did the same thing this weekend a gound wire snaped in half out of the blue.
i'll take a look now cause i have nothing to do exept fixing the by my self
Check your spark plugs and wires and make sure the plugs are all in pretty tight and that all the wires are snap on tight to the end of the plugs. Mine did what you described after my header install as i didnt have the plugs in tight enough and two wires were on loose. It started idling around 500 rpms almost dying out then would fluctuate up and down between 500 rpms and 1000 rpms until it died.
Thanks guys for the help.
Help is here,we are taking the car back to the garage.
And about the ground wire and spark plugs i'll be checking them also.
I thank you guys again for the help. I'll be posting back the prblem.
Also thinking battery since volt gauge went down/check gauges light/clicking trying to start. Wondering about the new alternator too. Before my battery died and popped the hatch noticed the voltage was reading lower at lights with the AC on, ignored it for a couple days - luckily mine died sitting overnight in my driveway and not in the middle of nowhere.
