Throwing code for MAP sensor after intake install....
ok so i installed my fast 90 intake and now im throwin a code for my MAP sensor....has anyone ever had this problem? why is it doing this? also now my car doesnt like to start the first time i turn the key...itll fire but then die?
That's what she said...
It may have popped out. What you can do is go to the stealership and buy just the little rubber part that's on the MAP sensor. The sensor itself is like $90, but the rubber piece is only like $5. It will fit MUCH better after this.
Make sure it's plugged in right too.
ya its plugged in right unless the connector is capable of being plugged in upside down? i cant see it but it went in fine. and the map sensor itself is still in the manifold so it didnt pop out. but yea i will go down to the stealership monday as i do need a few things.
ok so i finally got around to pulling my old MAP sensor out for inspection and when i did it was wet!? like the tip that is inside the manifold was wet with what smelled like gasoline....is this normal? what would have caused my map sensor tyo get soaked in gas inside of the intake manifold?
Kleeborp the Moderator™
Originally Posted by C Murda
anyone?....so i figured the only way this can happen is through the EVAP system which plugs into the front of my manifold....but last i heard it wasnt supposed to release this much gas to cause my MAP sensor to fail right?
