Check Engine light on and blinking
Old 03-07-2007, 04:59 PM
motomike734's Avatar
Default Check Engine light on and blinking
car started acting up like it wasnt running on all 8 except when i go wot then the light started to blink!!!! I think i fouled a plug
Old 03-07-2007, 05:10 PM
2001NBMZ28's Avatar
Baby it down to your nearest auto zone and have the code read.
Old 03-07-2007, 05:12 PM
forgot to add i just found out the same day the light started blinking i have my rear o2s in the front. I just added new intake tb lts ory,tr6s and wires. The tune is comming ive been putting around nd its been running like crap then sunday on my way home it acted like the car wasnt running on all 8, what could it be
Old 03-07-2007, 05:13 PM
oneBADDz's Avatar
If it's blinking it means there's a misfire. A-Zone can likely tell you what cylinder it's on and then you can swap the plug wire or coil from a good cylinder to see if one of those is the culprit. If it is, the misfire code will more to a different cylinder
Old 03-07-2007, 05:15 PM
oneBADDz's Avatar
lol, you posted when I was typing
I think all the O2s are the same, it's likely a plug wire connection. make sure you got them all plugged in good
i put 100 miles on after the mods i just stated and then this happen. Do you think its something major or just bc i put the rear o2s in the front and its been telling it **** codes?
Old 03-07-2007, 05:16 PM
i talked to one of the mods and the rear o2s are diffrent from the front
Old 03-07-2007, 05:32 PM
anyone!!!??????????
Old 03-07-2007, 06:21 PM
Z28LS1camaroguy's Avatar
my friend accidentally plugged his rear O2s in the front and the only thing it really did was make it run rich and his gas mileage sucked really badly, im talking 150 miles a tank. i could see it fouling up some plugs if you did this and that would be the worst case i think, but you never know.
Old 03-07-2007, 06:35 PM
does a blinking ses light mean its in the plug, wires or coil or is there other meaning of it
Old 03-07-2007, 07:11 PM
i need to no!!
Old 03-07-2007, 07:24 PM
99huggercamaro's Avatar
a blinkin light is a missfire. re-check all plug wires and check the plugs. thats or a fuel injector. maybe a wire was barely on and when u hit wot it kicked it off... where are u located?
Old 03-07-2007, 07:44 PM
it only runs good at wot or high rpms, im upstate ny. Would a scan tell me if its a plug or injector?
Old 03-07-2007, 07:54 PM
but at idle its rough?
Old 03-07-2007, 07:56 PM
no not really, but like i said i did alot of things to it including unplgging egr air and rear o2s without a tune.
Old 03-07-2007, 07:57 PM
u may also have a vacum leak. i didnt see u did an intake...start the car and spray carb cleaner around the intake area and see if the idle changes.
it didnt start blinking till about 100 miles then it did this
Old 03-07-2007, 07:58 PM
get it scanned and see what codes are in the computer...then go from there...that would be the easyest.
Old 03-07-2007, 07:59 PM
yah ik , im going saturday for the rest of the wiring for my dry shot, do you tink it will be ok to dyno my car without the window switch installed?
Old 03-07-2007, 08:00 PM
i know nothin about nos sorry
