AIR Removal with PICS!
#163
I've located all of the parts. From what I can see the pump is on the DS fender behind the fog light. the hose goes up over the brake booster and to a (servo/thingy). From there the hoes go to the driver side and passenger side headers
there is a small plastic air tube that comes from the back of the manifold that goes to that (servo/thingy).<---what is this called? Do I remove all that??
Then of course I'll get a check engine light. My car came with a hand held tuner (fukin junk) so I'll have to have a tune.
I've ordered my true duals/headers to day so I hoping this will all work out.
#164
I removed everything associated with it including the vacuum solenoid thing in the back. I also pulled the fuses for the air pump. If you are gonna have it tuned they will take care of the CEL light you get.
#167
