Installed LS6 Intake Yesterday
Old 03-12-2007, 09:58 AM
NOBR8KSS's Avatar
Default Installed LS6 Intake Yesterday
Everything went smooth. I found out the hard way that you need to remove the plastic clips from the knock-sensor wires...they kept the manifold from seating all the way on the heads.
I got in a hurry and wound up launching one of the clips into the intake port of the drivers side head. It fell into a port with the valve OPEN!
I was soooo lucky...I was able to turn the motor over with a wrench until the valve closed and then used a coat hanger to slide the plastic clip out. The instant I touched it, it fell onto the valve.
After that incident, everything went well and I didn't even break the oil pressure sending unit.
JC
Old 03-12-2007, 10:31 AM
tbick's Avatar
congrats, I recently installed a ls6 intake as well. Im glad you were able to get that plastic clip out of the head. I was able to keep the clips on, but I also hammered a little on the coolant lines to get them to sit lower. Good job on not breaking the oil pressure sending unit and enjoy the new extra power
Old 03-12-2007, 11:54 AM
coocooknu's Avatar
Wow thats lucky you got that clip out, i was in too much of a hurry when i took out my old intake that i broke the oil pressure sending unit. You will definatly love that new found power, i sure did!!
Old 03-12-2007, 12:00 PM
DOUBT IT's Avatar
Glad you got the clip out. When I pulled the fuel rail, two of the little retainers on the ends of the injectors fell down in the ports...
Talk about your butt-hole puckering up for a second...
Old 03-12-2007, 01:39 PM
bad6as's Avatar
hows the gains feel?
Old 03-13-2007, 08:39 AM
NOBR8KSS's Avatar
I actually haven't driven the car yet...I'll take it out this weekend, though. I just started it up to check for leaks...all seems well!
Old 03-15-2007, 10:32 AM
NOBR8KSS's Avatar
I drove the car last night. It was a decent SOTP improvement int he top end. I can tell the PCM is still learning a little.
I also noticed the exhaust note was slightly deeper and more throaty at WOT.
Definitely worthwhile, especially since the cam is going in soon!
Old 03-15-2007, 11:35 PM
TERMINAL VELOCITY's Avatar
Good job on fishing the clip out,the extra power will be worth it.
Old 03-16-2007, 02:03 AM
GTOpowered240sx's Avatar
Please excuse my ignorance, but isn't the LS6 intake already on the 04' GTO LS1's? I was told my LS1 already had the "corvette" intake, but Im not sure if thats what they meant.
Old 03-16-2007, 02:20 AM
bww3588's Avatar
yes, all LS1's 01+ have the LS6 intake.
