Egr Removal
Old 03-20-2007, 06:29 PM
Numba1Stunna's Avatar
Default Egr Removal
tried search got little info im sure some one can help me here. i really want to remove the egr and air but ive been told that deleting the egr can cause problems like blowing head gaskets(doubt that can happen just wanna make sure) also ive never had a visual for emissions, but will a tune enable me to pass emissions. i plan on getting an ls6 intake in the future but i would really like to get rid of the egr asap
Old 03-20-2007, 06:31 PM
car is 2000 camaro z28 still stock just lid
Old 03-20-2007, 06:32 PM
any info is much appreciated thanks
Old 03-20-2007, 06:35 PM
Tainted's Avatar
yes you can remove it and there is no ill effects other than an SES light. to pass emissions you will need a tune though but id jsut wait till you get the LS6 intake
Old 03-20-2007, 06:37 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Taking off the EGR will not blow any gaskets.
Since you have no visual dont stress about it, you will just need to get the codes deleted. You will pass the sniffer no problem. Plus with the ls6 you are going to have to get rid of the egr unless you go with the SLP manifold.
Just start unbolting ****, thats what I did atleast and had everything out of the car in the matter of an hour or so. Its no big deal besides the codes...which is no big deal as well.
Old 03-20-2007, 08:59 PM
CBRAKLR85's Avatar
this may be a dumb question but im also going to remove the egr and air from my 00
z-28 and i wanted to know if you can make adjustments in the computer with a diablo sport tuner so the check engine light isnt on all the time? again this is a dumb question so please go easy on me!
thanks
TJ
Old 03-21-2007, 09:22 AM
'99bluez's Avatar
the diablo should be able to get rid of your codes. And for the original poster i would just wait until you get the LS6 - thats what i did. If you do it now then you will need to buy a extra block off plate to put on the manifold.
Old 03-21-2007, 12:37 PM
Lithium's Avatar
I am almost positive that those tuners will not get rid of the code. You will need to get the code removed with LS1edit or HPtuners.
Old 03-21-2007, 02:53 PM
CBRAKLR85's Avatar
thats what i thought. i know you can check codes with the diablo but im sure you can not remove the egr system from the computer with one.
thanks for the help
TJ
Old 03-21-2007, 03:48 PM
89Formulaws6's Avatar
you just get a ses light when removen the egr right? no driveability probs? cause i am gonna be installing some LT's without emission crap soon
no e-tests here
i've heard of some people leaving the egr plugged in and it just sits there in the engine bay....idk how true that is
first ls1 car
Old 03-21-2007, 03:52 PM
Amoretti's Avatar
Correct. Just an SES light, no driveability differences.
If you were to just disconnect your EGR without removing it or blocking it off, I would think that you would get a pretty nasty vacuum leak.
Old 03-21-2007, 04:15 PM
no what i ment was just unplugging the connector clip
but thanks for the info
Old 03-21-2007, 07:40 PM
Janko98Z's Avatar
I removed my egr on my 98 when I insalled my ls6 manifold and cut the pipes to the module but left it on the bracket with the electrical plugged in - no ses light. The egr is controlled by other sensors and will continue to pseudo function even if the manifolds pipes are gone.
Old 03-21-2007, 09:33 PM
Candyredz28's Avatar
What do u do with all the wiring that goes to the egr? If you do get rid of the wiring, where do u start cutting.
Old 03-22-2007, 12:04 AM
sledneck687's Avatar
i just taped mine up, and ziptied it back
