Throttle body isssue
It seems as if ever since I got my car it has been up and down on performance, here lately it just hasnt felt very strong. I think this may be a slight problem, I think this is why my car is so damn slowand only ran 13s. Any of you guys ever had this problem?
1st Picture, this is me holding the TB wide open with my hand
2nd Picture, this is with the gas pedal held to the floor
Thats ridiculous. There is way too much slack in your throttle cable. You can adjust but I can't remember how. Thats like running all the time at 1/4 throttle. Someone tell him how to fix this please.
Luke
Luke
Luke
Luke
Yea thats what I figured haha, just mainly seeing if anybody else ran into this. I was looking at how to adjust it earlier but I really dont see how, but I havnt looked into it veyr much.
Restricted User
Your problem is that you have a 98-99 style throttle body on a 00-02 car. I am assuming your car is a 00-02 from your sig. If thats the case you need the larger throttle cam from the later years, or you need to get a cable for a 98-99.
Yoy also might be able to shorten the cable by pulling more through the pedal.
Just my luck, the TB is suppose to be a Bo White TB, at least thats what teh guy that I bought the car from told me. Ill see if I can get some of the slack out before going buy a new throttle cable. And whats a throttle cam?
Restricted User
Is the car you have that tb on a 00-02?
If it is then that is the wrong tb for that car. 98-99 cars used a smaller throttle cam, 00-02 cars used a larger throttle cam. The tb in the picture is actually a truck tb, which is very similar to a 98-99 tb. You need a tb thats made for a 00-02, not one for a 98-99.
You can tell its a tb off a 6.0l truck becasue it has a orange spring, a longer vacume port at the top left and the coolant tubes are both straight on the bottom. And from the pictures it is done by bo white. Tim
It is a truck TB, and more than likely one of mine.....from a while back. If you have your old TB you can send that one to me and put your original one back on while I swap the shaft and spring out and update it. Just get with me on a PM.
if you follow your cable back towards your ecu there should be a little deal on the cable which a clip comes out of, you can adjust is doing that. I had the same problem with my bbk tb bc it was off a 98 and mines a 00.
Thanks guys, Ill try to adjust it, if not I get a shorter cable. Thanks for the offer Bo, but I dont have the orginal TB nor do I have the time for any down time at this moment.
