what thermastat is everyone running
Old 03-27-2007, 09:27 PM
kosovobandit's Avatar
Default what thermastat is everyone running
I have a 99 6spd vette and am going to a cooler thermastat and wanted to know what everyone is running. and are you having any adverse effects from it. I thank you for the advice and I was going to run the 160 degree from hypertech.
Old 03-27-2007, 09:32 PM
Tainted's Avatar
I run a stock thermostat but have my pcm tune set up so my fans kick on earlier so I have no need for a lower thermo
Old 03-27-2007, 09:33 PM
2_wacko's Avatar
Stock.
Old 03-27-2007, 09:36 PM
Reject's Avatar
stock
Old 03-28-2007, 08:48 AM
senicalj4579's Avatar
i use 160 hypertech. i got the fans programed to come on at 190 from the stock 210 setting
Old 03-28-2007, 10:29 AM
bczee's Avatar
I use a Hypertech 180 and have my fans are controlled by a standalone SPAL controller and come on around 195-200, but it runs around 180.
Old 03-28-2007, 10:47 AM
Ace$nyper's Avatar
Stock here.
Old 03-28-2007, 11:49 AM
Renegade's Avatar
Stock here as well, I did have a 160 on my last camaro and didn't see much of a difference at all, except that it wasn't as warm in the winter, not sure if the Thermo effected that or if it was just the car. But I wouldn't do a thermo unless I had money and time to burn or actually had a cooling problem.
Old 03-28-2007, 08:37 PM
HottLS1Z's Avatar
160 here when the car was a bolt on car it seemes to run better cooler and also noticed more oil preassure due to the engine staying cooler too.
Old 03-28-2007, 10:06 PM
ss_girl's Avatar
I'm running a 160 from hypertech as well.
Old 03-28-2007, 10:11 PM
Kleeborp the Moderator™
MeentSS02's Avatar
180 in the summer here, 195 in the winter.
Old 03-28-2007, 11:19 PM
98camaroLS1M6's Avatar
160 with fans programmed by hp tuners, big difference from stock thermostat, on the dyno, the difference between 195* and 175*F was 9rwhp!! Coolant temp makes a big difference.
Old 03-28-2007, 11:37 PM
Renegade's Avatar
That's kind of surprising, maybe I was wrong and a thermo would be worth it, suppose it's cheap enough to buy and easy enough to install.
Would recommend to the poster doing anything that requires a tune with the thermo so you can have it all tuned at once and save some $$$ since it looks like you'll see the most power out of it with a tune.
Old 03-29-2007, 12:04 AM
Rob98LS1's Avatar
stock
Old 03-29-2007, 12:55 AM
BayAreaSS's Avatar
Stock.....with fan settings lowered with Hptuners
Old 03-29-2007, 03:21 AM
BLKWS.6's Avatar
Cooler engine temps can cause premature ring wear and do not necessarily mean more hp. Most engines actually perform better hotter (to an extent). You have a polymer intake and pretty much a striaght shot for airflow so not much heat is absorbed by incoming air reguardless of reasonable engine temp. I would recommend a stock T-stat and fan-setting.
Old 03-29-2007, 07:45 AM
V6 Bird's Avatar
stock is best.
