side exit exhaust camaro
Do a search for 'boom tubes'.. they're a nascar style side exhaust. I contemplated putting them on my car but later decided against it. Not many guys out there have them but you could check em out if you'd like.
I saw a guy about 2-3 weeks ago with side exhaust on a Silver Z28 in Lafayette, Indiana. I have only seen the car once and it was not from this area from the plates. Super loud and he had exhaust soot on the side of his car.
I have plans for a side exit exhaust that fixes the ground clearance problem without using boom tubes. What I don't know about is whether soot or fumes are going to be a problem.
I think soot can be controlled by tuning the engine. My car is black, so as long as it doesn't actually hurt the paint it won't be noticable. Hopefully tuning will cure it. What about fumes though? Will running no cats make the smell noticable or not?
What would happen?
fumes would be no worse than the thousands of people that have exhaust systems dumped under the car. I'm doing mine with the dr. gas street boom tubes (the spintrap muffler ones) H pipe, exit on both sides in front of the rear wheel wells. Considering doing it with oval pipe, but I'm not sure if the extra LITTLE bit of clearance is worth it. My car is dropped on pro-kit springs in front and stock height in rear so I don't think it'll be a problem. I ran tsp true duals before so clearance won't be any worse at the least. I'll post pics when it's done sometime this month.
I saw some pictures with someone who had roush style side tips coming out of their side skirts, and it looked perfect. but i think those tips are like 150 each. ill try to find the pic
What would happen?
and since when does high octane exhaust fumes smell bad lol
