edelbrock victor jr intake
has anyone on here used this intake i am thinking about buying it, any input would be nice, thanks
I have one on my solid roller setup. It looks nice with the intake ell and all but I can't use an STB with it since it's higher then my FAST was. Depending on how high you're spinning your 408 it may not be much good to you. I've also heard that they're not real good out of the box unless they're ported.
Im running it. Though I didn't have a chance to use with FI (where it would shine) I still have it. Going Procharger this year however I'm using it NA right now. You will loose a little bottom end torque but the upper rpms come live with this intake. With your 408 you might not even see a difference in the lower end. Porting them is a + with a 408ci.
