pining a ATI crank pulley.
The pin dosent fit "snug" in the hole. It will slip out but i guessing that the key way and the harmonic blot will hold the pin in place. MY hole it right at 6 oclock. So i was going to use a little silicone to hold the pin while i install the damper. I dont usederstand the reason i can boil the end of the damper? ATI says you can. heres a link please let me know if i am wrong.
http://www.atiperformanceproducts.co...structions.htm
ALUMINUM HUBS
NOTE: If using a front cover teflon seal, you must use a “Speedy Sleeve” or a steel hub.
Aluminum hubs have a .002” press fit between the crank and the hub. DO NOT ALTER the press fit of the hub in any way! The press fit on the aluminum hub is slightly tighter to compensate for the elasticity of the aluminum.
To install, heat the hub in boiling water for five minutes to expand the hub slightly and help it slide onto the crank. Use gloves to handle the hub after it has been heated. After installing the hub, allow time for it to cool.
ALUMINUM HUBS
