MSD Digital 6 Plus Ignition Box
Old 05-08-2007, 10:01 AM
Restricted User
Zero4488's Avatar
Default MSD Digital 6 Plus Ignition Box
Is their any way to hook up a digital 6 plus ignition box on an LS1? and if so, how?
Old 05-08-2007, 10:17 AM
Torque_Wrench's Avatar
i'M PRETTY SURE THAT ALL YOU CAN USE ON A pcm CONTRILLED ls1 IA A MSD TIMING TWISTER.
Old 05-08-2007, 10:36 AM
Sweet71's Avatar
No you cant use them there made for a motor with a distributor, and ours are distributorless ignition systems, but they make a box similar its called a DIS system
http://www.msdignition.com/ignition_25_62111_62151.htm
Old 05-08-2007, 12:44 PM
Restricted User
Zero4488's Avatar
Ok...but do I need a 2 channel or a 4 channel box?
Old 05-10-2007, 12:54 PM
Restricted User
Zero4488's Avatar
2 channel or 4 channel?
Old 05-10-2007, 01:43 PM
I'm not for sure on the channel....I don;t use the DIS Ignition box. I'd say to be safe, if you have to have one....do the 4 channel.
Old 05-10-2007, 02:01 PM
Restricted User
Zero4488's Avatar
i don't know how that would work...but ok...lol...anyother ignition setups I can use?
Old 05-10-2007, 03:30 PM
Why are you dead bent on an ignition system? Your car has a good one built in.
Old 05-10-2007, 03:58 PM
Da Swami's Avatar
I seem to remember the MSD 6AL works with the LS1.
Old 05-10-2007, 04:14 PM
A-Dub's Avatar
You remembered wrong
Old 05-10-2007, 04:29 PM
Restricted User
Zero4488's Avatar
The reason I wan an ignition system if for the two step rev limiter for launching and timing retard for my nitrous....
Old 05-10-2007, 04:35 PM
mcamarols1's Avatar
get EFI Live, more worth the $$$$ and the time
Old 05-10-2007, 06:09 PM
Restricted User
Zero4488's Avatar
Is EFI Live hard to use?
Old 05-10-2007, 09:51 PM
mcamarols1's Avatar
im not familiar w/ EFI, but ive been on HPT, people tell me its just as easy, im sure EFI live has a feature that allows u to run two diffrent tunes, in ur case one for NA, and the other for nitrous, go look in the tunning section, i heard EFI live has a demo version u can download so u can see what kind of tunning possibilitys it has. HPT is another good choice, im just not sure if they offer the feature for 2 tunes, give both a call, they will guide u in the right direction.
Old 05-11-2007, 01:36 AM
Sweet71's Avatar
use a msd timing twister and a 2 step from synergy motorsports
Old 05-11-2007, 11:08 AM
Restricted User
Zero4488's Avatar
How much is the 2 step from synergy?
Quick Reply: MSD Digital 6 Plus Ignition Box
