Intake Manifold Install
Old 05-15-2007, 01:47 PM
99RebelZ28's Avatar
Default Intake Manifold Install
I was wondering where I could find an install guide for the intake manifold (purchased the BBK SSI Intake Manifold). Not sure if I wanna put this on my self due to how difficult it may be. Thanks
Old 05-15-2007, 01:59 PM
black01_WS6's Avatar
Its not really to hard to do, I think install university has one, or do a search for one, and you will find it.
Old 05-15-2007, 02:08 PM
motoo344's Avatar
I dunno how different the install would be from a ls6 to bbk, but ls1howto.com has a an ls6 swap.
Old 05-15-2007, 04:52 PM
Shinigami2x4's Avatar
unbolt, unplug, replace. Its cake but there is always going to be somthing that breaks or gets misplaced.
Old 05-15-2007, 05:29 PM
00SSLS1's Avatar
look on ls1howto.com there's a write up for the ls6 swap
Old 05-15-2007, 05:53 PM
styoung's Avatar
so true. just take your time. when you rush is when you **** something up.
Old 05-15-2007, 08:12 PM
Black Z/28's Avatar
I just did mine 2 weekends ago. The only problem I had was getting the brake booster hose back on. The BBK is taller in the back and I still have my AIR system which leaves little room back there. Also, once installed, the brake booster hose sits tight up against the oil pressure sending unit:
(I had to Lift the manifold up and over the oil pressure sending unit)
To gain a little clearance, I bent the brass barb out a little so that I could snap the connector back down on the sender.
Other than that, piece of cake.
Old 05-16-2007, 11:11 AM
radkon's Avatar
You can probably follow this for the most part:
http://fuelairspark.com/Instructions/147.asp
Old 05-16-2007, 02:29 PM
Black Z/28's Avatar
That's a high quality install document. Credit to FAST.
Old 05-16-2007, 06:00 PM
98noscamaross's Avatar
not to highjack the thread, but im doing the same swap this weekend and i was wondering if it have to replace my coolant lines to the 01-02 style.
Old 05-17-2007, 02:13 AM
00SSLS1's Avatar
yes or or can cut the bottom of the manifold to fit your existing coolant lines
Old 05-17-2007, 08:52 AM
Juiced2000SS's Avatar
Get a hammer and sharp chisel, have someone hold the mainfold for you and go to town knocking the plastic grid off the bottom. Fits fine after.
Old 05-17-2007, 03:05 PM
curtisad's Avatar
be very careful to not snap the oil pressure sending unit clean off! Not hard to do at all! Trust me!
Old 05-17-2007, 04:52 PM
5_02ls1's Avatar
ls1howto.com
Old 05-17-2007, 05:06 PM
99RebelZ28's Avatar
Thanks for the help!
Old 05-25-2007, 10:08 AM
gameovergt's Avatar
nice thread
Old 05-25-2007, 11:46 AM
KurtRardin's Avatar
http://ls1howto.com/index.php?article=5
