about to dremel ribs on Ls6 for clearance, any1 have the pic?
I'm in the middle of an Ls6 swap and i'm looking for the pic that shows where to grind down the bottom ribs for clearance over the stock ls1 coolant lines.
Does anyone have a link to that pic?
TIA...
TIA...
Originally Posted by cals400ex
i have been told using a chisel is easier. i don't know from experience but it is somethign else to look in to.
I probably should've stuck around a few more minutes to read up on the chisel recommendations. I ended up dremeling it with a grinding bit and cutting wheel...took about ~40 min.
In retrospect...a chisel probably would've made it a better experience. Nothing quite like hot manifold slag flying all over your arms and face while grinding away.
