!EGR done, now exhaust leaks, what to do?
Old 08-12-2007, 09:11 PM
shudog's Avatar
Default !EGR done, now exhaust leaks, what to do?
I tightened it down as much as possible. The leak isn't bad, but I can hear it under acceleration, and I can feel a little air escaping if I put my finger down there on the driver side. I reused the factory gasket, it looked in good condition. THis is very annoying.
Old 08-12-2007, 10:49 PM
Sideways240sx's Avatar
im assuming you got the speed inc block off plates? I used the paper gaskets that came with my longtubes, and i have no leaks at all.
If its that big of a deal, maybe pull it off and use a little black permatex?
Chris
Old 08-12-2007, 11:40 PM
c0ncEpT's Avatar
Take it off and use some silicone or something on top of the gasket
Old 08-13-2007, 06:51 AM
shudog's Avatar
I'll try tightening it up more tonight after work when it's cold, if that doesn't get a good seal, I'll try some high temp permatex or gasket maker.
Old 08-13-2007, 07:57 AM
98Camarod's Avatar
My stock gasket was in several pieces. I'm not sure how you managed to keep yours in tact and reuse it. I cut out my own for the egr and air and threw some high temp permatex on it and it's been fine.
Old 08-13-2007, 08:09 AM
tylerdj's Avatar
If the bolt isn't getting tight enough to make a good seal on that plate you could add some washers to both bolts. I had to do this on mine.
Old 08-13-2007, 01:24 PM
shudog's Avatar
I'll do both the high temp permatex and the washers on the plate to put extra pressure down, thanks guys
Old 08-13-2007, 02:41 PM
BLK02TA's Avatar
I would put the washers on. When I deleted my AIR the bolts would bottom out on the hole. I didn't know this and broke the head off one of the bolts.
