Just bought a clear MTI lid, problem?
Old 08-30-2007, 06:13 PM
ThunderZ28's Avatar
Default Just bought a clear MTI lid, problem?
I just installed an MTI Clear lid.
Buttoned it up, and got home to check everything out, and the clips that hold it on where off, and it had slid forward out of the tab holders..
what can I do to fix this??
is there a fix?
thanks
Old 08-30-2007, 06:18 PM
woods94z's Avatar
what kind of air filter do you have?
Old 08-30-2007, 06:21 PM
enos44's Avatar
ive heard of some ppl taking out the filter tray to get that lid to fit right especially with a k&n filter, personally i dont have this problem i have an slp lid
Old 08-30-2007, 06:33 PM
ThunderZ28's Avatar
K&N is what I have in there...
Old 08-30-2007, 06:34 PM
g-ryde1's Avatar
this might help you out. mine did the same thing until i cut out the back then no problems.
https://ls1tech.com/forums/showpost....8&postcount=10
Old 08-30-2007, 06:37 PM
woods94z's Avatar
i've heard the k&n sits up a little higher the the others
ThunderZ28's Avatar
so the Filter box gets in the way of the Maf sensor, and the lid??
I will have to fix that tonight..
Thanks
Old 08-30-2007, 06:39 PM
g-ryde1's Avatar
Thanks
pretty much causes the lid to unbuckle itself. also ensure the lid is secured into the filter box
Old 08-30-2007, 06:41 PM
ThunderZ28's Avatar
I didnt put the gasket on the lid, maybe that will help after I cut away the box a little ..
Old 08-30-2007, 06:43 PM
enos44's Avatar
there was a gasket on the lid?
Old 08-30-2007, 06:47 PM
ThunderZ28's Avatar
no the filter camw with one.. didnt put it on tho.
Old 08-30-2007, 08:45 PM
ssgunny's Avatar
Wow, you really had to cut the plastic base out to get it to fit? I know it is different variables but I have the SLP bellows and lid and a Delphi 85mm MAF (and 3 3/4" ID sylicone coupler between the MAF and lid) and it makes "light" contact with the base but no nead to cut. I have no contact with the hood either.
Old 08-30-2007, 09:07 PM
g-ryde1's Avatar
yep on both my Z28 (stock) and my boys WS6 (408 Stoker) which is pictured contacted the base the cut made it fit perfect
Old 08-30-2007, 10:22 PM
ThunderZ28's Avatar
Yeah, my Maf is rubbing pretty bad on the box, and it was really hard to get the lid on..
It has it in a pretty bad bind..
Just got home, and I ma heading out into the garage to trim it up
I'll post some pics later as well
Old 08-30-2007, 11:06 PM
GMmexican's Avatar
My MTI carbon fiber fits fine...with the fram paper filter
Old 08-30-2007, 11:44 PM
ThunderZ28's Avatar
Just finished up..
took it for a test spin, and no problems..
the lid stayed latched this time.
Thanks g-ryde1 for the info..
i'll post some pics in a bit.
Old 08-31-2007, 01:09 AM
WannaBcamaroguy's Avatar
This little problem is only for the clear mti lids correct??
Old 08-31-2007, 01:20 AM
g-ryde1's Avatar
ima tryit out on my boys SLP tomorrow ima do a write-up and hopefully we can get it stickied
Old 08-31-2007, 11:33 AM
ThunderZ28's Avatar
I have a buddy with a wisper lid with the same problem, I am gonna try this mod out to see if it will fix his problem as well.
here are some pics.
this is where the MAf/lid was rubbing on the filter tray.
I made the cut as wide as the Maf is ,
and then I cut up on the filter tray untill it didnt touch the lid any longer
Old 09-01-2007, 01:56 AM
g-ryde1's Avatar
write-up added (hopefully sticky-worthy)
https://ls1tech.com/forums/generation-iii-external-engine/776082-mti-clear-lid-clearance-issue-install-pics.html
