Vibration when reving car
Don't know if this is in the write forum, but anyway...seems like it is progressively worse. In neutral when I rev the engine, I am having some vibration now. Never started doing it until after my converter install. It was slightly noticable at first, the other day it was really noticable...sometimes I can feel it under acceleration as well. Any clues?
Re: Vibration when reving car
Perhaps the tranny mount is busted. You can replace with stock, but many of us use the Poly Mount from Summit etc.
Also, could be a busted torque arm mount. Same deal, replace with poly.
Finally, double check how your exhaust is hanging. Could be rubbing when getting on it.
Well, I am getting my Vig swapped out next weekend, so I will check all of those things next weekend...unless my car rattles apart before then...oh well
The TC could be out of balance! If your getting vibration in Neutral or park while reving, it's not the tranny mount, torque arm or exhaust IMO. Check all the TC bolts as mentioned...
Dan
Dan
