Am I hurting performance with my 2.5" duals?
H/C car with about 430 rwhp. The exhaust is pacesetters & 2.5" TD's with Spiral Flo's. (The cam is a 223/227.) I'm curious if I would gain anything by going to a 3" setup; the only thing is I'm also worried about ground clearance. What's the verdict?
True. To adress this issue, you would also have to adress any other power-robbing parts you have, such as: Flywheel, Driveshaft, Rear-end, Mufflers, Clutch, HVMC equipped longtubes and etc, etc. I've heard of people losing around 20 horses by switching to Torq Thrust II's because of their 27 lbs of rotating mass!
Taken from td sticky
Q. What size piping should I go with?
A. The most common sizes for duals are 2.5 and 3. The general rule is that if plan on lowering your ride, go with 2.5, if you are going to stay at stock height go with 3. Anymore than 500HP and you will probably want to go with 3", unless lowering takes priority. There are lowered cars that run 3 with no problems. Both sizes will support plenty of power, more than almost all of us will likely make.
IDK. I will eventually get to a true dual set-up and find out for myself one day.
