epoxied TB question
Old 09-27-2007, 11:53 AM
WonQuickZ28's Avatar
Default epoxied TB question
Has anyone ever consider or even tried tacking a small cut to fit piece of sheet metal to fill the divit in the TB instead of putting epoxy in there? I dont imagine it would be to hard if you can decently weld aluminum and have access to a grinder, plus it wouldnt break off and get into the motor.
Old 09-27-2007, 01:08 PM
95 Z28's Avatar
I'd choose that over putting epoxy on my TB. I still don't understand why people full that in though, it's not worth it IMO. But regarding your question, if you can weld aluminum well and make it look nice and clean then i guess it'd be alright.
Old 09-29-2007, 08:56 PM
welding it would actually be the easy part, tacking it in there. grinding it smooth would be harder I would think
Old 09-29-2007, 09:28 PM
Restricted User
socmguy's Avatar
What? and then what? drill a hole in it? Also, I've never heard of epoxy/JB weld breaking off a TB and getting into the motor. That just sounds ridiculous to me.
Old 09-30-2007, 12:06 AM
Sunset'01Z's Avatar
what good is the epoxy anyways? the only thing that really helps is taking the ridge off, bump stop, and hollowing it out a little. you wont gain much if anything from any of the other mods.
Old 09-30-2007, 12:27 AM
Restricted User
socmguy's Avatar
it may help a little with air velocity. It's worth $3.89 if you ask me.
Old 09-30-2007, 12:44 AM
Tainted's Avatar
I had mine epoxied. Ive seen1 case where someones broke off, but a clean surface is the key to making it stick.
Old 09-30-2007, 10:55 AM
FireSilverLullaby's Avatar
Yeah someone on here had theirs brake off and took pictures of it in their intake runner.
