Easiest Way to Remove CrankBolt
Old 09-29-2007, 09:59 PM
DSRCAM's Avatar
Default Easiest Way to Remove CrankBolt
I Just Figured The Easiest Way To Remove The Harmonic Balancer Bolt And It Will Save You Alot Of Time Beside Using The Impact Gun But What I Used Was A Big Screw Driver,of Course A Breaker Bar,24 Mm Impact Socket, Pipe To Go Over The Breaker Bar... What I Did Was Wedge The Big Screw Driver Into The Pulley And It Got Caught Right Behind The Ac Compressor And Thats All U Need Is To Stop That Crank Pulley From Turning And You Can Get That Bolt Out And Get That Crank Pulley And To Remove That Just Follow Ls1howto.com Info Its Real Quick It Took Me Bout 15 Mins To Get That Bolt And Pulley Out Way Easier Then Putting A Screw Driver In The Flywheel If U Need Any More Info Get At Me Whenever... Thanks Ls1tech You Guys Are Always Helpfull...
Old 09-29-2007, 11:30 PM
Dex
Dex's Avatar
Yea this has been the method for years and years and years and years and years and years. Its been around for a minute. At least you figured it out some people dont.
Old 09-29-2007, 11:44 PM
DSRCAM's Avatar
yea i know man, me and my pops figured it out quick now to put it back thats gonna be fun..
Old 09-30-2007, 12:31 AM
Restricted User
socmguy's Avatar
interesting. Can you post some picks on how to get it off and on?
Old 09-30-2007, 01:02 AM
DSRCAM's Avatar
ill post them tommorrow is that fine i have church tommorrow and wont get back til noon but ill give u a quick write up...
Old 09-30-2007, 10:46 PM
DSRCAM's Avatar
heres a pic of what i did to remove the crank bolt i got the pic from ls1howto.com but you can get the idea of my lil drawing sorry my paint skills arent that good..
Old 09-30-2007, 11:01 PM
Mike101's Avatar
cheater bar and started the car is what I did to break the bolt loose
Old 09-30-2007, 11:02 PM
andrew69_04's Avatar
Thats what i did....works like charm
Old 09-30-2007, 11:08 PM
DSRCAM's Avatar
yea it saves alot of time trust me do it this way i know when i install it, its wont take as long also but highly highly recommened this method....
