how do you remove a broken power steering pulley?
The OE plastic pulley cracked in shipping, I've swapped heads on this motor and all of the pulley has fallen off except the hub and I'm replacing the pulley with a metal one.
How do you get the thing apart? There's an allen screw in the center and I've put a fair bit of force on that and can't get it to budge
use this tool, it the same tool for our GM power steering pulley , you can get it at any part store. I used it to changed mine.
http://www.stu-offroad.com/steering/...pspulley-1.htm
All I have left on the pump is the metal, splined spindle though, and I need to get that off to get my metal pulley on. So that's just a friction fit? The hex bolt in the center does nothing?
