Why Do I Have To Change Balancer Bolt Upon Cam Swap?
Kleeborp the Moderator™
As stated, the stock GM bolt is a torque-to-yield bolt, so when properly tightened, the bolt has technically failed. That's why you don't reuse them...people have done it before, and they have even gotten away with it, but why take the chance?
If you don't ever want to have to replace the bolt, ARP makes one that is not a torque to yield design that can be reused. Not quite as cheap as the GM bolt though...
I'm thinking the major reason people find the crank bolt hole has been stripped is because people try to re-use the TTY bolts that shear apart while torquing them down. Just a guess though....
$4!!!!!!! I just called a local GM store, they had to order me one and the lady quoted me $34.00 dealer price! what the hell is this, did she order me the wrong bolt? What happens if the bolt spins while drivin the vehicle?
The bolt is quite large, coated and special with its tensile strength. I'm not surprised at that price. I don't know where people get the low price on them but I've never looked into it. My heads and cam came with the bolt in the kit. There are a couple of discounters around that may be able to get you a better price. I definitely would check with NAPA or other parts stores to make sure it isn't a standard available item.
Internet Mechanic
