JAAM ram air or FTRA?
do either of these actually work and if so, which one is better? also, can you run the 2 together? what would that do? thanks for the input.
Not recommended, because the 'ram air' pressure from one would be relieved by the other.
according to the FTRA, the hood doesnt get enough air going through it to make a difference. it says that the air goes up and over the hood and hits the windshield and misses the hood all together. but then again, thats what the company trying to sell the product is saying. just wondering if anyone had some experience of their own.
The JAAM kit is made for all the WS6 people that want to make their hood functional. It is still limited by the design of the hood but as part of the kit install, baffles are removed, the hood is sealed to the air box and the lower nostrils are also made functional (which the BGRA kit did not do). When JAAM tested just using the upper nostrils, they did not see a significant pressure increase. They only saw an increase when all 4 nostrils were used.
If you ask which one would give you better performance, our belief is the the FTRA will perfom better due to the fact the Fbodies are bottom breathers and the kit takes air from a high pressure air source on the vehicle.
Running the two together will not yield a larger performance gain that just running one.
Thanks
Thanks
Thanks
Thanks
I'm running a Lowes $25 seal . It effectively lowered my IATs to within a few degrees of ambient. I've considered the JAAM for a more stock look and longer lasting seal, but am waiting to see some performance data. My seals on my current setup will probably have to be changed every other year or so, but the price was right. Here's a snapshot:
Thanks
Thanks
i was running low 13s @ 105-106mph before i added the BGRA to my WS6 back just before production stoped for them. my cousin at the time was running 12.75@105-106mph with his fox body.
I added the BGRA to my car and we ended up racing on the street. i pulled him pretty bad in our 2 races. the next year i added a 3500rpm stall and ran 12.27@110mph
does anyone have any #s from having both and testing them? or maybe 2 of you just ran a dyno after you put them on your cars? i would like to know the actual outcome of the 2. thanks.
A dyno will not show the gains of the ram air pressure. It may show a slight gain due to the cooler IAT, but the real test is track time.
