oil pressure sendor
oil pressure sendor
that is the tall sensor on the back of the engine block next to the cam sensor right
how tight is that sensor supposed to be there is a gap between it and the engine and i cant budge it any tighter also what size is the bolt on it??
I think mine is starting to act up, last night i noticed the gauge showing my pressure alittle below 80psi and i was cruising at maybe 2k rpms. Im definetly going to change it out though when i swap to an LS6.
-Joel
-Joel
good chance of it breakin anyway so that's a smart decision i had to drive 30 miles to find an oil sendin unit in stock and when i was there i bought an Sensor Socket . . . bought it at autozone and if i remember correctly it was called an 02 sensor socket not a oil sending unit socket.
