Got my 2002 6 speed T/A today!!
OK first off! I cant leave anything alone. What racing ring and pinion (for street racing) would you go with? How much extra horses can I get with new heads and 1.6 ratio rockers (or even 1.7's)? Which brand makes the best heads? which brand rockers would you go with? After this do i get a new chip?--Thanks Alan
thanks for the help. Thanks Texas director, if your going to be a wise *** dont say anything at all. Maybe this explains some of the people in Texas. U dont have to be stuck up just because you know something others dont! Moron!
Ok. you got a good start by getting the 02'.. it has some LS6 parts, Like the intake and maybe the block.
As the others stated, try adding some of the normal bolt ones.. K&N Filter, A after market lid (air cleaner Top, This is to increase and better the air flow). A Cat back system and Headers and Off Road Y pipe. Ported Throttle Body and follow all of this with a good Dyno Tune.. and you should be good until you want to take the next step... Head and Cam.
good luck.. Suggest you search on each subject to research and learn, you will be up to speed soon.
1 Post
hey if u want people to help u out then u cant be an ******* like dat! everybody on this forum is here to help each other, and if ur gonna act that way then please ask for advice else where! and the stickys are the best way to start! u really get to learn alot, thats the way i started
((((((Administrator))))))
Moron? ...you're the one that can't use the search or read the sticky threads, and you get a warning for insulting members. Nice start you have here on LS1TECH.com!
