Fuel Rail Leaks...??
Old 11-22-2007, 11:21 AM
2002RamAir's Avatar
Default Fuel Rail Leaks...??
I just installed new fuel rails for ls1speed on my fbody..after having to pull off my intake to get some AIR bracket off to make everything fit right...I now have a leak issue...It is from the disconnect that hooks up to the factory fuel line...I have tightened the fitting as much as I can and it still seems to leak...Is it possiable for the braided hose to leak some? Any suggestions would be great???
Old 11-23-2007, 12:05 PM
2002RamAir's Avatar
Anyone have any idea how I can get that quick connect to stop leaking???
Old 11-23-2007, 12:28 PM
fuseone's Avatar
maybe some type of oring or seal? ripped if there is one on there
Old 11-23-2007, 03:21 PM
2002RamAir's Avatar
no Orings in there...
Old 11-23-2007, 03:39 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Is it where the quick connect attached to the hard line, or where it attaches to an AN fitting? Regardless, it shouldn't be leaking.
Old 11-23-2007, 09:42 PM
2002RamAir's Avatar
It is hard to tell because the whole fitting stays wet...seems to be mostly from the hardline to quick connect tho...the an fitting is tightened as tight as it will go so I hope its not leaking there...
Old 11-23-2007, 09:43 PM
98Camarod's Avatar
What did you use on the fitting to seal it and what type of fitting is it?
Old 11-25-2007, 01:13 PM
2002RamAir's Avatar
Used thread sealant on all the npt fitting...same stuff I used for my nitrous stuff...The fitting is a an type fitting with the braided hose going into it. That then screws into a quick connect style fitting that attaches to the factory hard line....It is not leaking enough to drop...just seems to always stay wet with gas....
Old 11-25-2007, 07:16 PM
98Camarod's Avatar
I found that the thread sealant is good to use on the an fittings, but for the pipe threads I had to use thread tape. The gas seemed to seep out every so slowly with the thread sealant.
