Fuel Rail Leaks...??
I just installed new fuel rails for ls1speed on my fbody..after having to pull off my intake to get some AIR bracket off to make everything fit right...I now have a leak issue...It is from the disconnect that hooks up to the factory fuel line...I have tightened the fitting as much as I can and it still seems to leak...Is it possiable for the braided hose to leak some? Any suggestions would be great???
It is hard to tell because the whole fitting stays wet...seems to be mostly from the hardline to quick connect tho...the an fitting is tightened as tight as it will go so I hope its not leaking there...
Used thread sealant on all the npt fitting...same stuff I used for my nitrous stuff...The fitting is a an type fitting with the braided hose going into it. That then screws into a quick connect style fitting that attaches to the factory hard line....It is not leaking enough to drop...just seems to always stay wet with gas....
