FLP header? 3.5 main pipe ?
Old 12-02-2007, 11:50 PM
Restricted User
Lawnboy's Avatar
Default FLP header? 3.5 main pipe ?
My car is a 01 SS M6 , i am having a forged 347 installed over the winter ,
with 9.25 compression , and i will be running 15 PSI of boost. I am at 10PSI now on stock motor making 540 to the wheels. (methanol injected)
OK my current exhaust system consist of 1 3/4" Long tube FLP headers with 2.5" Y pipe (no cats) and my stock SLP dual dual Exhaust ( 3" main over the axle pipe and slp dual dual muffler.
I am thinking on having a 3.5" over the axle main pipe made up (I think 4" is over kill )and taper it down to fit my SLP dual dual stock muffler , I dont like the way SLP cushed the 3" pipe where it goes over the axle.
has any one done this? any sound clips , performance difference? etc.
I have been hearing my exhaust would limit my HP and power goals.
I might also have a custom 3" Y made up , the 2.5 FLP is ok but where it meets up a the main 3" over the axle pipe , there is a bottle neck there, i hear one guy that cut this off and replaced a 3" spool piece picked up 14 HP. Thats a lot of HP for removing just the bottle neck.
thank you for your help
Old 12-02-2007, 11:55 PM
Mean Green z28's Avatar
Mine's the same setup as you're looking into. I have a 3" y-pipe into a 3.5" collector catback system with a flowmaster single in/out with a dump on driver side (kinda looks like a V6 on steroids).
I made my whole exhaust setup from scratch and it sounds pretty nice, although the fact that I have twin cats and a muffler kinda robs a lot of power. May sell the setup or hollow out the cats and use a cutout.
Here's how it affected power ... granted my setup isn't optimal right now 'cos of a mismatch of parts ...
TH350 w/3500 stall, true duals with dumps ... 401RWHP
T-56, above exhaust (to make it more family friendly .. ) ... 403RWHP
Old 12-03-2007, 08:26 AM
Ragtop 99's Avatar
I did almost the identical thing. Custom Y with a proper merge exiting to a 3.5" intermediate pipe. I also put a 3.5" cutout in just before it went over the axle and narrowed down. Without a 3.5" cut-out you aren't gaining much; you will still have a 3" system when you really need more flow.
Old 12-03-2007, 12:36 PM
Restricted User
Lawnboy's Avatar
any pictures of the exhaust Ragtop 99 ??
Old 12-03-2007, 07:17 PM
Ragtop 99's Avatar
Y-Pipe
Underneath car with 3.5' QTP electric cut-out. You can see I have it neck back down to 3" to go over the axle. (some stuff looks messed up because it was post accident.)
Old 12-03-2007, 10:03 PM
Restricted User
Lawnboy's Avatar
so a 3.5 wont go over the rear axle, is there not enough room,
looks good otherwise
Old 12-03-2007, 10:06 PM
Grifter's Avatar
There is enough room for a 3.5" pipe. It knocks around alittle but that's mainly due to my stock MM.
Old 12-04-2007, 07:54 AM
Ragtop 99's Avatar
You can go 3.5" over the axle, but a D/D is 3" so you still have to narrow down to 3".
Mufflex (sp?) makes a 3.5" catback and maybe a 4" system. I liked my system. Pretty quiet unless I wanted to let everyone know I was coming.
Old 12-04-2007, 11:08 AM
Grifter's Avatar
I personally don't see why you would want to lower the pipe diameter, unless you're hooked on using the D/D.
My setup is a custom Mufflex. They do sell 4" systems aswell like you stated, that also fit over the axle.
Old 12-04-2007, 11:26 AM
Restricted User
Lawnboy's Avatar
Yes i like the stock look of the SLP D/D , and sound , its staying on no matter what i do .
Old 12-04-2007, 12:07 PM
Ragtop 99's Avatar
Same here. I wish my SS had come with the D/D. I have a magnaflow now which looks good, but the deep sound can be annoying at times with the top down.
Quick Reply: FLP header? 3.5 main pipe ?
