about to dyno my car...but front 02 is out
Old 12-23-2007, 04:27 AM
VtecDis's Avatar
Default about to dyno my car...but front 02 is out
couple of quick questions----my driver side front 02 is out, so im throwing an SES light. i know that it will effect my A/F mixture. Im planning to get headers and some bosch 13111's but not installed until Jan.
questions are....
1.will the front being out affect my rwhp??
2.will it help if i reset my car's comp right before the dyno?
3.anyone have any tips before the dyno? im a newb. will i need to do anything special?? i was thinking of changing my oil (its almost 3k now anyway) and cleaning my air filter
Old 12-23-2007, 04:36 AM
slowjoe99's Avatar
replace the sensor before dynoing
Old 12-23-2007, 08:00 AM
Viper's Avatar
To save the O2 for the dyno you might be able to get by with this. Buy a $10 propane torch from Lowes, take out the O2 and put it in a vice. Hit the end 4 times from each side for 30-60 seconds each to burn off the crap. Do not touch the sensor for 15-30 minutes as it will still be quite hot. This method saved a couple of O2's for me. Your best bet is to replace it before the dyno but the above might work and you'd only be out $10 if the light stays off and trims read OK.
Old 12-23-2007, 09:18 AM
shdybrady1988's Avatar
why not dyno it after the headers? You will be fine doing it before but why not just hold off alittle bit
Old 12-23-2007, 09:34 AM
bryan04h's Avatar
just replace the sensor man, while you are at it get your fuel injectors flushed out, check your spark plugs/wires
Old 12-23-2007, 09:43 AM
2vkiller's Avatar
Are you getting it dyno tuned or just making a pull to check rwhp? The 02 being bad will not effect a WOT pull because the pcm is not looking at the 02. It will only effect the drivability portion.
Old 12-23-2007, 12:47 PM
VtecDis's Avatar
Viper
-----interesting. i have a torch laying around.. ill try that thanks
shdybrady1988
-----its pretty much stock, so i wanted to get a baseline of what i have.
i plan on getting a tune after the headers anyway, so yeah...
bryan04h
-----thanks.. forgot about those.. i seafoamed about 9k ag0. so im up for another one.
2vkiller
-----just checking RWHP. and BIG THANKS... thats exactly the answer im looking for.
Old 12-23-2007, 12:54 PM
bryan04h's Avatar
no worries man, good luck with the dyno!
Old 12-23-2007, 10:14 PM
Grimes's Avatar
FYI, many ppl are now saying not to use the Bosch 13111's anymore, because they may not work as well as stock.
Old 12-23-2007, 11:17 PM
SladeX's Avatar
if it's just for dyno testing's sake, swap the front and rear sensors. They're identical, you'll just get a different code indicating that the rear is out
Old 12-23-2007, 11:51 PM
Black99CamaroSS's Avatar
+1....
Old 12-24-2007, 11:02 AM
VtecDis's Avatar
yeah, ive been reading that as well.. when i do my tuning, i plan to go to a tuner that can adjust for a slower reading 02 sensor.. so hopefully that wil solve my problem...
as far as swapping the front and rear's out, i actually already did that when i installed my 02 sims. unfortunately my rear's are shot as well. ill have to try that torch method as a temp fix
